2 Attachment(s)
Control vertex problem in Autodesk Maya 2010.
Hi Friends,
I am new to Autodesk Maya. I have Maya 2010. I am learning it myself. I have a video tutorial of Human Head Modeling and am Trying to model a human head from it. But I got some problems with vertex. I am not able to get correct result. I made some changes in settings but still I am not getting correct result. So I need your help and hope you all will help me.
Below is the link of image of the tutorial [I want that result]........................
http://i889.photobucket.com/albums/a...gdev/maya1.jpg
And Below is the link of image which result I am getting...........
http://i889.photobucket.com/albums/a...gdev/maya2.jpg
So pl. Help Me why I am not getting correct result? What changes should I make in settings?
I also have attached images of that problem. Pl. check it.
Maya 1. jpg is the result which I want and Maya2.jpg is the result which I am getting..
Thanks.
Re: Control vertex problem in Autodesk Maya 2010.
Congrats on your first post, and welcome to the forums!
I'm guessing you got your result by single-selecting a vertex and manipulating, instead of window-selecting a 'vertex' (which is really all vertexes in that location from the right side, orthographically).
Watch your tutorial again... I bet the tutor is window-selecting, which permits uniform manipulation of vertexes, instead of the non-uniform manipulation you're getting.
Hope this helps!
It looks like you're only selecting one vertex at a time and moving it. But you're modeling with a cube shape, so that means that you should be selecting all verticies behind the one you're trying to move as well as the one you're trying to move.
So instead of just clicking once to grab the vertex you see, you have to click and drag a selection over the vertex, so it selects the verticies behind it as well.
