Is there anyway to switch the default logo to my company logo instead the Navisworks logo in the HTML (Tabular) report?
Printable View
If you look in the Clash_Files folder where all the JPGs are stored, you will find a < logo.jpg >. Replace this logo with the one you want. I did hafta tweak the size of the logo to more closely match the size, both physically and byte-wise before it would show correctly.
You could also just insert another logo with a different name into the file and edit the .xml files that Navisworks uses to create the reports. Make sure you have admin priviliges on your computer though. You can also edit these to adjust the default report appearances
Thanks Dennis, your suggestion should work. I was hoping that I could find where Navisworks pulls the "logo" from and replace it there.
OK, here it is. You can replace the generic Navisworks Logo with your own here:
Local Disk>Program Files>Autodesk>Navisworks Manage 2012>Images
I renamed the default logo to "logo-nw". I resized my company logo to a comparible size to the default (190x70) and saved it as "logo" in the Images Folder. When I ran the test Clash Report, the logo was my companies logo. Simple. Thanks Dennis for giving me the idea.
what is HTML? i don't know because i am new seo guy.
