Create a warning if grading is too steep
So, we had it brought up that it would be helpful if we had a label or an area in a surface/corridor if thengrading exceeded a certain percentage.
I think it's a great idea, but not sure which direction to go. Would an expression for a label with an "IF" statement would work, or if anyone else has done this, some ideas would be much appreciated!
Thanks in advance!!
- JDE
Re: Create a warning if grading is too steep
In the surface properties you could set a slope surface analysis with one range for slopes greater than a set slope and it will hatch those surface triangles that fit within that range. Just edit the initial range that it creates from the surface to set a minimum slope to start the range.
