Inventor Tips and Tricks: starting with - Switch between trim and extend
there are tooo few inventor tips here - so lets do something about it:
as most autocad users know you can toggle between the extend and trim command by pressing the shift key. Would you be surprised to know inventor does the same thing?
Within sketch mode, press the shift key while doing a trim to toggle to extend. Goes the other way around as well.
RE: Inventor tip: Switch between trim an extrend
My personal 'simple but gets missed'. If you start your work feature tool (Workplane, axis, point), and right click, there is a option to 'repeat command'. Checking it allows you to place multiple work features without restarting the tool every time.
1 Attachment(s)
RE: Inventor Tips and Tricks: starting with - Switch between trim and extend
In AutoCAD, it's possible to use the divide command to place equispaced points on a spline. In Inventor, it can also be done.
After you have created, imported, etc your spline, create a workpoint on the end of your spline. Open the "Rectangular Pattern", pick the workpoint as the feature, select the spline as Direction 1, Enter in the number of points, and change "Spacing" to "Curve Length"
Its also possible to do the same with workplanes, and keep each workplane square to the spline. Create a workplane at the end of the spline by picking the end point of the spline, and then the spline itself. This workplane is square to the end of the spline. Open the "Rectangular Pattern", pick the workplane as the feature, and follow the instructions as per the workpoints. However, before you hit "OK", open the details ">>", and change the setting for Orientation (in the lower window) from Identical to Direction 1 (see jpg file below), this is what keeps the Workplanes square to the spline as they are translated.
oooh good one on the array - ron
within sketch mode - there is a nice offset option:
the offset feature will standard select a bundle of objects, like a closed contour or objects that are attached with one another. This is because the option "Loop Select" is on. During the offset command - click RMB to get access to this option "Loop Select" and turn it off. Now you are able to select independent objects fromwhere you wanne do the offset.
This setting also has a regkey (i case you would be interested): HKEY_CURRENT_USER\Software\Autodesk\Inventor\RegistryVersionxxSystem\Preferences\Sketch\Offset Loops
1 Attachment(s)
I like using the offset tool to help make a basic four hole pattern.
If you offset a rectangle from the outside perimeter of the part, you can place four holes at each vertex of the rectangle.
Once you're done, you can control the hole's offset using one dimension!
long time no new tips here:
ok did you know there is a way to create a section view without a parent view (and therfore section line).
Create a new view of a random part. Click on the view an start a new sketch - draw a rectangle all around the view, so that the view is completely surrounded by the rectangle sketch. Exit the sketch, and start the breakout view.
The breakout is the rectangle, just define the depth and there is your full section view.
http://home.pct.edu/~jmather/AU2006/MA13-3%20Mather.pdf
A hundred or so.
Hinge Assembly - Tutorial for beginners
This tutorial on part creation provides a step by step instruction on creating an assembly using the hinge base parts and hinge pin that we created in the following tutorials – Creating Hinge Base Part and Creating Hinge Pin. Follow the below link for more....
http://www.3dcadresources.com/invent...ly/figure7.jpg
Cheers!
