1 Attachment(s)
Color override not (completely) working
I've got a few models exported from Revit MEP 2014 to Navisworks 2015. When I attempt to override the color of a piping system only the fittings (elbows, tees, etc) change color. The pipes remain a dark gray (as indicated in the attached image). Note that the short piece of vertical piping is selected, shows that it's color is red, however, after it's deselected it remains dark gray. There is no insulation on these pipes so it's not that. Any thoughts? Suggestions??
http://forums.augi.com/attachment.ph...id=96587&stc=1
Re: Color override not (completely) working
Are you down far enough into the selection tree?
Is the render mode set for full render, with materials applied to the object?
I had it on FULL RENDER instead of SHADED. Shaded gives me the result I'm looking for. Thanks for pointing me in the right direction.
