Unable to close active document from revit 2012 api C#
I would like to ask a little help regarding my issue.
I have a push button in a revit plug in. When i click on it i would like to invoke two different commands(custom commands). Is that possible?
I use Revit 2012 ARchitecture API and my platform is C# .net
Re: Unable to close active document from revit 2012 api C#
Welcome to AUGI, and congrats on your first post! :beer:
Please post the code you've written, to make it easier for others to help you.
Cheers
Closing the active document isn't supported, but there are workarounds that would allow you to do so. See here for more information: http://thebuildingcoder.typepad.com/...-document.html, http://thebuildingcoder.typepad.com/...hy-not-to.html
When you say invoke commands, you do mean calling a native Revit function, or a function that you've written yourself?
If you want to call a native Revit function, then that is not supported in 2012.
In 2013, you can override a native Revit command with your own command.
In 2014, you can call a native Revit command to run after the completion of your own command, in addition to being able to override a native command.
If you want to call your own commands, then you simply need to implement an IExternalCommand that runs all of the functions that you want.
