5 Attachment(s)
Cul-De-Sac Corridor / Surface Issues
I am getting weird surface results after creating a corridor and cul-de-sac. It appears that the corridor feature lines that are generated are crossing each other when the assembly wraps around the endpoint of the road centerline alignment. I have attached a few screen shots. Any ideas?
Thanks!
Attachment 108911
Attachment 108910
Attachment 108912
Attachment 108909
Attachment 108908
Re: Cul-De-Sac Corridor / Surface Issues
You might have a better result IF your assembly followed the Centerline until 19+70
And then insert a gegine where the assemblies follow your EP and then target bact to Center thereafter.
1 Attachment(s)
brian.127267
Thanks!
You may have this sorted out already.
This is to followup and share a different approach with you.
There a few concepts not explicity discussed here so I welcome your questions.
Helper corridor and assembly a concept I use to aid in design
Then the actual corridor leverages off of that.
Take note of name sub-assembly components and how those are used in targeting corridor paarrameters.
Attachment 108955
