Drawing window not maximized
When AutoCAD Civil 3D - Land Desktop Companion opens a drawing (previously created) the drawing window is not maximized. (The main window is.)
This happens EVERY TIME, despite saving the drawing in a maximized window.
Any suggestions?
I have tried many things to fix this but it is still opening files in a smaller window.
Any suggestions are appreciated!!
Re: Drawing window not maximized
I believe if you go to your CUI and remove a pull down menu that you are not using very often will cure this problem. I suggest removing the window or the help menu.
Another option is to set a workspace with the window maximized,
and use a startup script to set that workspace current. this has solved the problem for me
