Summary: I would like to be able to select the corridor lines with a crossing/window, using multiple picks and also by specifying the codes and have the program create feature lines for all selected corridor lines. It would be even better if a list of codes was displayed in a dialog with check boxes next to each code.
After selecting the desired corridor lines the Create Feature Line From Corridor dialog should appear allowing the user to specify Site, name, style, layer, smoothing and whether or not the new feature line is linked to the corridor.
Description: I would like to see an easier way to create feature lines from a corridor when multiple feature lines are needed.
How Used: The option to link feature lines to a corridor was added in the 2009 version. This was a great enhancement.
I would like to see an easier way to create feature lines from a corridor when multiple feature lines are needed. Currently it creates one at a time, even when corridor lines are selected with a crossing. I would like to be able to select the corridor lines with a crossing/window, using multiple picks and also by specifying the codes and have the program create feature lines for all selected corridor lines. Since this is a wish let me continue. It would be even cooler if a list of codes was displayed in a dialog with check boxes next to each code.
Feature Affinity: Feature Lines
Submitted By: Jeff Paulsen on March 16, 2009
