Thread: How to join splines in VIZ 5
    2009-04
    Default How to join splines in VIZ 5
    Is there a simple way to join lines and arcs to make a solid splines to extrude shapes?
    Thanks.
    jack
    Design Visualization Moderator stusic's Avatar
    2004-10
    Denver, Colorado
    1,515
    Default Re: How to join splines in VIZ 5
    You can convert two splines into a single spline by:
    1.) clicking one of the splines you would like to connect,
    2.) in the Modify panel, under the "Geometry" rollout, click the "Attach" button (will highlight yellow),
    3.) click the spline(s) you want to add,
    4.) "un"click the "Attach" button.
    If you would like to connect the ends of the splines (they must be editable splines; if you have arcs, convert them):
    5.) Go to the vertex subobject mode of the spline you just joined
    6.) slect the vertex of one of the ends of the spline.
    7.) click "Connect" (will highlight yellow)
    8.) click the vertex you want to join, and drag to the vertex you want it to connect to.
    9.) unclick "Connect".
    These instructions are really for Max, but I think it still applies.
    Let us know if that helps.
  1. T-SPLINES for 3DS MAX
    By realchristo in forum 3ds Max - Wish List
    Last Post: 2012-06-16, 08:10 AM
  2. Splines
    By sarahh62907188 in forum Revit Architecture - Families
    Last Post: 2011-05-05, 07:46 AM
  3. splines
    By ivan.239950 in forum Revit Architecture - General
    Last Post: 2010-08-30, 10:01 PM
  4. Converting Revit splines to AutoCAD splines
    By drubinoff in forum Revit Architecture - General
    Last Post: 2010-03-22, 01:51 PM
  5. Join roof - cant join over 2 seperate ones
    By still.james in forum Revit Architecture - General
    Last Post: 2008-05-15, 04:42 PM
