I have my title blocks setup with fields inside of attributes all linked to the Sheet set manager. Everything works fine as long as everyone uses the S.S.M. to update the title block, but you can still double click on the block, change the attribute & loose the link to the field.
Is there anyway to lock the attribute so that it can't be tampered with & loose the field link?
I've tried using dtext but when I use dtext within a block my fields don't update even with fieldeval set to 31.
thanks.
