AFTER SELECTING THE FAMILY, I AM ABLE TO EDIT AND PUT THE LABEL F1, 277V, 185WATS and also locate the IES file. However, when I touch with the mouse, the fixture shows 0volts, 0 VA.
I am very new in Revit.
WHAT I AM DOING WRONG ?
Thanks in advance.
Thanks in advance.
Hovering show the Family Name and Type. If you want the hover tooltip to change, you will need to rename your family from the element properties.
Kathy Taylor
Senior Structural Draftsperson & Proprietor
TaylorCAD
www.taylorcad.com.au
I don't suffer from insanity - I enjoy it!
Revit User Phase 3, 4, 5, 4, 3, 5, 4.....
Kathy,
Thanks for your prompt advice. I know that there in Sidney is almost midnight and here in Dallas is almost 9AM. Have a nice weekend. I am right now in my office trying to solve all these puzzles.
ps: i like you quote but i do not get the part hase 3,4,5, 4,3, 5,4, ...
Kathy,
I tried your advice but no luck. Please, do not give up and tell more .
Thanks in advance.
The connector in your fixture family also has parameters for voltage and apparent load. You need to make them equal to the numbers you input into the family.
Click on the connector and go to Element Properties
Click the small button to the far right of the Voltage parameter
Pick the family parameter where you input the voltage
repeat the process for the apparent load, setting it equal to the parameter where you input the wattage
this will give the connector the same values that you input into the family
