I have searched thru some of the forums here and played with the new massing in 2010.
From what I understand is that if you use model lines to create your profile you are unable to edit the profile to change the shape. Which I have tested and I am unable to change the shape.
From what I understand is that if you use referance lines you basicly have the same affect as in 2009, with the exception that I have to manualy delete the mass to modify the referance lines. Which I have tested and I am able to do.
The thing I want to know is:
How do I turn off the blue reference planes that over power my "sketch" reference lines? I can't see what I am doing because those blue boxes cover my sketch.
Thanks
