Thread: text strings on schedules?
    2009-01
    345
    Default text strings on schedules?
    I have a some equipment with a type mark 'FTC' and a numeric mark (1,2,3...). I want in my schedule a column for 'symbol' that says FTC-1, FTC-2, etc. Is there a way to do this as a string of text? So for each piece of equipment would read (type mark)-(mark). I found some stuff on how to make formulas in schedules but nothing about using parameters like this. Thanks in advance.
    2016-01
    Garden Grove, CA
    344
    Default Re: text strings on schedules?
    You cannot link the 2 parameters together. All you can do is add a secondary parameter with the appearance you want. Basically double work. You could try to do if/then statement formulas, but i think that would be more work than it's actually worth, if it actually does work. You might as well just do it manually or do what is commonly suggested by Autodesk "just accept it"
  1. Linking text strings
    By DaleSmith in forum Revit Architecture - General
    Last Post: 2011-11-25, 09:26 AM
  2. Predefined text strings
    By robert.1.hall72202 in forum AutoCAD Customization
    Last Post: 2007-07-12, 08:17 PM
  3. Text strings in Dimensions
    By DaveP in forum Revit Architecture - Wish List
    Last Post: 2006-06-26, 12:34 AM
  4. Match text strings by selecting
    By spaynter in forum AutoLISP
    Last Post: 2005-10-12, 08:32 PM
  5. formating text strings
    By rwbaker in forum VBA/COM Interop
    Last Post: 2005-09-20, 06:02 PM
