Thread: Revit Error Warning Elements have changed category. Tags for these elements are now of the wrong category and will be del
    2008-02
    San Francisco
    85
    Default Revit Error Warning Elements have changed category. Tags for these elements are now of the wrong category and will be del
    We have a bunch of these warnings in a project. "Elements have changed category. Tags for these elements are now of the wrong category and will be deleted"
    Some tagged components were changed from plumbing fixture to specialty equipment. It seems likethe tags have already been deleted becasue that's what the warning suggests and we can't find the tags in any views. I would think this should just be a temporary warning that goes away.
    How do we get rid of this warning? Would changing the family back to plumbing fixture bring the tags back?
    Thanks
    2015-10
    31
    Default Re: Revit Error Warning Elements have changed category. Tags for these elements are now of the wrong category and will be del
    I have now come across this same error and can not seem to find a way to resolve / remove it. Has anyone developed a solution?
    Thanks.
    2006-06
    Toronto, ON
    2,386
    Quote Originally Posted by mcblum View Post
    Thanks.
    Can't you select the warning under the review warnings dialog box and hit the Show button to see if Revit locates where the "deleted" tags are (were)?
    Andre Carvalho
    2015-10
    31
    Yes you can, but as the first post stated, even if the tag is deleted by Revit or yourself, the warning still remains. If I cut and paste the object back it fixes the problem, but I have to re-tag / re-dimension everything then - not ideal.
    Thanks.
  1. Being able to unhide elements from a hidden category
    Last Post: 2014-10-23, 08:03 PM
  2. Component in Wrong Category
    By denisgonzalezg189 in forum Revit Architecture - General
    Last Post: 2010-09-14, 03:07 AM
  3. Air Terminal Wrong Category?
    By gvluisi in forum Revit MEP - General
    Last Post: 2009-12-14, 07:25 PM
  4. Elements by Category
    By fwp in forum Revit - API
    Last Post: 2006-12-24, 04:17 AM
