Results 1 to 10 of 11
Thread: display relative coords???
    2006-08
    UK
    13
    Default display relative coords???
    I'm using 2008 - in the olden days F6 toggled between coords off, on - absolute and on - relative.
    How do I get relative coords to display in the status bar during a command?
    If I right click the status bar coords box it gives me the off or absolute options but relative is greyed out
    COORDS system variable 1 or 2 makes no difference ?
    I know about dynamic input displayed at the cross hairs but I have that nonsence switched off
    0,0,0 The Origin
    8,570
    Default Re: display relative coords???
    Try setting DYNPICOORDS = 0. Then start (say) the Line command, pick the start point then right-click the coordinate display and pick Relative.
    2006-10
    51
    oooh vey cleber!! that was annoying me too. Fankoo Jabs
    0,0,0 The Origin
    8,570
    Quote Originally Posted by tracy.findlater View Post
    I read the question, looked in Help, experimented. ~shrug~
    AUGI Addict jpaulsen's Avatar
    2002-04
    Colorado
    2,020
    Right-click on the coordinates in the status bar while in a command that can use relative coordinates, for example, the line command. Then you will see relative or absolute as one of your choices. Also you can pick (left-click) on the coordinates in the status bar to toggle between the options that apply to your current command.
    2006-08
    UK
    13
    Quote Originally Posted by jaberwok View Post
    thats what I did too, but it seems it doesn't work with rectangle command ~shrug~
    2015-11
    Jo'burg SA
    4,512
    Quote Originally Posted by Forsh View Post
    That's because of the way RECTANGLE works. Unfortunately when asking for the 2nd point it doesn't use the 1st point as a reference. It has some other form of obtaining a point which doesn't comply with the same thing in (say) the LINE command.
    The RECT can only allow absolute coords or coords off.
    2001-08
    61
    With the exception of PC designers, does anyone else actually use absolute coordinates for anything?
    2002-04
    Colorado
    2,020
    Civil Engineers and Surveyors use them all the time.
    0,0,0 The Origin
    8,570
    but you can still use @dX,dY.
    :don't cry:
  1. Using fields in a block to display x,y coords
    By ajzoch in forum AutoCAD Fields
    Last Post: 2017-08-08, 11:28 AM
  2. Field to display point coordinates relative to CURRENT ucs, not WORLD UCS
    By jpcadconsulting347236 in forum AutoCAD Fields
    Last Post: 2015-04-16, 07:27 PM
  3. How to enter relative length AND relative angle?
    By Yancka in forum AutoCAD General
    Last Post: 2009-04-17, 06:17 AM
  4. Won't display cursor coords
    By wdyoung158645 in forum AutoCAD General
    Last Post: 2008-03-03, 11:41 AM
  5. Field for coords relative to current UCS
    Last Post: 2006-02-10, 11:52 PM
