Thread: Copying Objects takes avery long time!
    2009-02
    Default Copying Objects takes avery long time!
    Hey guys, long time view first time poster. Your advice has helped solve all my ACAD problems......until now! It is just in one dwg but every time I copy an object it takes maybe 3 or 4 minutes to come up, in which the program does not respond.
    This is very frustrating as I have a few hundred trees to copy and little time!
    HELP!
    Stats:
    ACAD 2008 Full
    Vista
    Thanks in advance
    2015-11
    Jo'burg SA
    4,512
    Default Re: Copying Objects takes avery long time!
    Welcome to AUGI & congrats on your 1st post.
    There could be something re the "trees" you're copying which makes them difficult to select. E.g. hatching inside them, too much detail, 3D? Are they all blocks? Are you using annotative scales (especially with hatching)?
    What happens if you set HIGHLIGHT=0? And the Selection Preview in Options/Selection turned off.
    2009-02
    Thanks for replying. It does not matter what the object is, it could be as simple as a polyline.
    I tried both highlight and selection preview and neither made a difference.
    If I use 'CTRL+SHIFT+C' it happens, if I use the CP command it is fine?
    It just happened to me again in another drawing when I copied an object from one drawing to another.
    Any other ideas?
    All AUGI, all the time Norton_cad's Avatar
    2016-02
    Sydney, Australia
    512
    It's probably junk files from previous crashes, or an Audit on the problem files.
    Close any autodesk programs, and do a search for *.ac$;*.err;*.dmp & delete them. Probably a defrag of your PC wouldn't hurt. Restart ACAD, open the problem file & type in Audit then Y to fix any errors.
    Let us know if this solves it.
    Ohm's Law - Electricity follows the path of least resistance.
    Regards,
    Mark Norton,
    2008-09
    4
    You can try to check your scalelist and reset it.
    2015-11
    Jo'burg SA
    4,512
    Try purging registered applications. Type the following at the command line (beware the minus prefix so the dialog doesn't open):
    -PURGE
    R
    N
  1. 2014: TAKES A LONG TIME TO SWITCH BETWEEN LAYOUTS
    By MLYONS505048 in forum AutoCAD General
    Last Post: 2014-01-15, 08:59 PM
  2. Applying Hatch patterns always takes a long time...
    By pgastelum77763 in forum AutoCAD General
    Last Post: 2012-09-17, 06:31 PM
  3. paste takes a long time
    By lee.johnson in forum AutoCAD General
    Last Post: 2010-05-19, 01:50 PM
  4. Purge Unused takes a really long time.
    By jj mac in forum Revit Architecture - General
    Last Post: 2009-12-14, 04:20 PM
  5. OPEN takes a long time
    By LanceMcHatton in forum Hardware
    Last Post: 2009-10-19, 07:59 AM
