Results 1 to 9 of 9
Thread: Deploy Tool bar
    2008-06
    Rochester, NY
    109
    Default Deploy Tool bar
    Hi,
    What is the easiest way of deploying a custom tool bar I made to all my users without disrupting their current workspace/profiles?
    Thanks
    Earth
    9,803
    Default Re: Deploy Tool bar
    If the toolbar resides in a menu that is accessible to everyone, and if everyone is pointed to the same location for their startup files, you could use a bit of lisp code to load the toolbar at startup.
    R.K. McSwain | CAD Panacea |
    2000-01
    Seattle WA USA
    5,859
    Quote Originally Posted by dwahl View Post
    Hi,
    Thanks
    I would agree with R.K. If the toolbar is located in an enterprise CUI file, it is pretty easy to make the toolbar available. Otherwise, if you are only using the main CUI file and everyone is using their own version, you are well and truly stuck.
    The only option in the latter case would be to make people use the Transfer tab to import the toolbar, but then you lose control of it. (Do you see the strong hints that you should be using an enterprise CUI file?)
    R. Robert Bell
    Design Technology Manager
    Stantec
    Member miles9x's Avatar
    2006-01
    North Dakota
    17
    Enterprise CUI is the way to go. Until then, I bet you could probably create your toolbar in a new CUI file that resides on your network. Then have your users use CUILOAD and browse to this file. It should load as a partial CUI under their current Main CUI. I did some quick testing and did this, exited AutoCAD, came back and the toolbars were available.
    That might work? Robert, what do you think?
    2000-01
    Seattle WA USA
    5,859
    Quote Originally Posted by miles9x View Post
    The only issue with that is that the interface will believe that the partial could be edited. Granted, the network folder could be set to read-only. But if they are going to create a partial CUIx to support the toolbar, why not just make an enterprise CUIx?
    R. Robert Bell
    Stantec
    100 Club Lemons's Avatar
    2001-06
    Beautiful Charleston, SC
    182
    Quote Originally Posted by RobertB View Post
    Please forgive my ignorance, but what is an enterprise CUIx?
    And I've seen CUIx in many places today and want to know if the "x" is a number assigned to the CUI or something else.
    I've been out of the customization game for a long, long time and I'm just now starting to get my feet wet again.
    Thanks much
    0,0,0 The Origin
    8,570
    It seems to be a newer version of XML. MS Office files are now "docx", "xlsx" etc..
    So, no, the x is x, not a placeholder for a number.
    Earth
    9,803
    Lightbulb Re: Deploy Tool bar
    Quote Originally Posted by Lemons View Post
    Also, CUI files were simply XML files with a changed extension. CUIx files are actually .ZIP files containing CUI files and other resource files.
    2000-01
    Seattle WA USA
    5,859
    Along with that, CUI files were used by versions of AutoCAD prior to 2010. AutoCAD 2010 went to the CUIX format, which is the compressed file containing all the files for the Customize User Interface.
    So, when I refer to the CUI or CUIX file, I simply leave the "x" in lower-case because it may, or may not, be the file extension the reader will see.
    R. Robert Bell
    Stantec
  1. Revit deploy scripts
    By Dave Lewis in forum Revit Architecture - General
    Last Post: 2009-01-26, 05:49 PM
  2. Best way to deploy page setups?
    By S_Newton in forum AutoCAD Plotting
    Last Post: 2008-09-15, 07:54 PM
  3. Deploy Batch File
    By dbanker in forum CAD Management - General
    Last Post: 2008-07-24, 02:34 PM
  4. Network Deploy Problem
    By sbrown in forum Revit Architecture - General
    Last Post: 2007-01-12, 07:07 PM
  5. Network Deploy to local drive
    By Steve_Bennett in forum Networks
    Last Post: 2006-02-23, 08:07 AM
