Thread: Can't add Items to QAT
    I could stop if I wanted to tonyisenhoff's Avatar
    Milwaukee, Wisconsin
    424
    Default Can't add Items to QAT
    Anyone else notice that you can't add commands to the QAT if the command is in a drop-down menu? Am I missing something?
    I've attached an example. I can add Cut, but not Uncut... Ditto for anything else in a drop-down.
    Actually neither of them can be added when you're in the drop-down menu. You have to do it in the ribbon without the drop-down expanded.
    All AUGI, all the time mmiles's Avatar
    2006-03
    New York, NY
    559
    Default Re: Can't add Items to QAT
    I don't have answer for that, but would like to add to the QAT question:
    I would like the switch views icon to appear in families - all the time - but it only seems to apply to the specific file that I am working on. Which means I would have to apply that each time i open a new family; defeating the purpose. Is there something that I am missing?
    I could stop if I wanted to jspartz's Avatar
    361
    Quote Originally Posted by mmiles View Post
    I noticed that too. You have to add the switch windows icon while in a family and while in a project and then it will show up in both. Unless you are saying you're adding it and it's not coming back, which in that case I would delete the UIState.dat file, which might be corrupt, located here by default: C:\Documents and Settings\*userprofile*\Local Settings\Application Data\Autodesk\Revit\Autodesk Revit Architecture 2010
    As far as adding items in a drop-down, you can't right now. I know the information is stored in the UIState.dat file but is encoded and you have to have a definition file to decode it. I don't believe it's open in API. You create the icon that will be used up there for add-ins, but I don't think you can force a button to display, since there would be two differing locations of information then (what you're telling it, and what the UIState file says).
    2006-03
    New York, NY
    559
    [quote=jspartz;974554]I noticed that too. You have to add the switch windows icon while in a family and while in a project and then it will show up in both. Unless you are saying you're adding it and it's not coming back, which in that case I would delete the UIState.dat file, which might be corrupt, located here by default: C:\Documents and Settings\*userprofile*\Local Settings\Application Data\Autodesk\Revit\Autodesk Revit Architecture 2010
    That is what I am saying. Intially, it seemed that it was something set in each individual family. Although, it appears to "stick" now. I first tested this upon intial install - pre-driver(s) update - and was experiencing crashing. My guess is it was not sticking due to the crashing. I now see that each family I open, it has the QAT as I would like.
    361
    Your guess is correct. The changes to the UI are saved to the UIState file upon exiting the program. If it crashes, the settings are never saved.
  1. Replies: 3
    Last Post: 2011-11-22, 08:21 PM
  2. Several Items
    By justina in forum Revit MEP - Wish List
    Last Post: 2011-09-13, 09:12 PM
  3. Moving items
    By foxy3298 in forum AutoCAD General
    Last Post: 2009-03-16, 01:17 PM
  4. Wish List items
    By The Monk in forum Revit Architecture - Wish List
    Last Post: 2005-07-09, 03:02 AM
