Hi. Sorry for my English...
I have a surface in C3D 2010 with several masks applied (all are material masks, render only). Also I have 3dsmax 2010 and object enabler. And I have some problems with connecting them one with other.
1. When I install OE, it says that it's status regarding to the 3dsmax 2010 is "Not Tested". The same "Not Tested" result is on 3dsmax design 2010.
2. After installing, when I'm trying to import c3d file into 3dsmax, I get message about unknown proxy objects.
3. I get single surface in 3dsmax, although I've selected option "derive by layer, split by material"
This happens both on XP 64-bit and XP 32-bit.
Does anybody know, what should I do?
P.S. I've begun this project in 2009 c3d and 3dsmax and also had some problems with transferring surface, split by materials, from c3d to 3dsmax. But there I could transfer some at least.
