Hi
I was wondering whether to have two similar connectors within a family and add them to the same system. Currently I am trying to add a chiller to a CHW flow and a CHW return system but the chiller has two inlets and two outlets. So far I have only been able to add the equipment and select one of the connectors. By adding the chiller, the system then becomes uninspectable.I did think of either splitting the family in half and adding two versions but that would produce incorrect schedules (for example). Another option would be to mess around with creating solid forms to create pipework with single CHWF & CHWR connectors but this would reduce the flexibility of the family when placing and piping up.
Am i Missing something in relation to adding mechanical equipment and connectors to systems ro can you only add one type of connector to a system? I will have the same problem with AHU's then also due to haveing more than one coil in each fed from the same LTHW pipework.
