Results 1 to 1 of 1
Thread: Hyperlink on FDO Features
    2002-02
    Saskatoon, SK Canada
    23
    Default Hyperlink on FDO Features
    Description:
    It would be extremely valuable if you could create a hyperlink on an FDO feature. This would allow you to use a feature attribute to generate a hyperlink, which would be benficial when plotted/published to DWF.
    How Used:
    Similar to how hyperlinks can be created for any feature source object in MapGuide. A URL string could be concatenated with a feature attribute to create a final URL hyperlink
    Feature Affinity:
    FDO, Features
    I do realize that the object properties, including feature attributes, can be published inside of the DWF, but I know of a few applications that rely on hyperlinks.
    Warren
    Last edited by warren.medernach; 2009-05-19 at 09:13 PM. Reason: Following the forum rules
  1. 2014: Hyperlink
    By gofy in forum Inventor - General
    Last Post: 2013-06-27, 04:57 PM
  2. Add Missing Features in Assembly level Features
    Last Post: 2012-10-12, 09:03 PM
  3. cant check in features - features remain in edit set
    By glenn22 in forum AutoCAD Map 3D - General
    Last Post: 2009-10-16, 05:18 PM
  4. NEED HYPERLINK HELP
    By RREDDEN.99202 in forum AutoCAD General
    Last Post: 2007-12-03, 02:56 PM
  5. Make existing features work before any more new features
    By Damo in forum Revit Architecture - Wish List
    Last Post: 2005-09-26, 04:49 PM
