Thread: Losing floor slabs when altering geometry
    2008-10
    Chicago, IL
    Default Losing floor slabs when altering geometry
    We have storefront with varying radii enclosing retail areas. Each time the storefront geometry is altered, both the floor slabs and ceilings 'disappear'. This isn't a user error (they are not being erased accidentally) but Revit appears to be dumping them when the geometry of the slabs change. Anyone have an idea as to how to stop this from happening?
    100 Club chris.macko125036's Avatar
    2006-10
    Chicago, IL
    133
    Default Re: Losing floor slabs when altering geometry
    That seems to happen when you have sketch lines trying to automatically follow walls or other objects that are more comlex than a simple box. Were your floors and ceilings created using the pick wall command? you can try editing them, deleting those sketch lines and just drawing in lines along the curved walls. You will have to manually update the floors and ceilings after you make changes, but it's much better than redrawing them everytime.
    Early Adopter sbrown's Avatar
    2003-05
    Coast to Coast
    4,440
    Prior to editing the wall use move/disjoin to remove the constraints of the floor and ceiling sketch from that wall.
    Scott D. Brown, AIA
    BECK
    2008-10
    Chicago, IL
    I'll give it a try. Thanks!
  1. Floor slabs
    By Valkin in forum Revit Architecture - General
    Last Post: 2012-12-10, 03:48 PM
  2. 2012: FOUNDATION SLABS, SLAB EDGES AND FLOOR SLABS: VISIBILITY ISSUES
    By BAMBAM in forum Revit Architecture - General
    Last Post: 2012-09-12, 04:48 PM
  3. Editing floor slabs
    By nextvkin in forum Revit Architecture - General
    Last Post: 2007-08-27, 04:14 PM
  4. Floor Slabs?
    By cmillman in forum ACA General
    Last Post: 2006-02-01, 05:20 PM
  5. Floor Slabs
    By gilbert.garcia in forum ACA General
    Last Post: 2005-12-05, 07:35 PM
