I'm looking for a way to strip out the "layout tab" name when creating plot files while using Publish. By default, Publish will automatically add the paperspace layout tab name to your output file name. The only way I've found around this, so far, is to manually rename each sheet in the Publish dialog after selecting all sheets for plotting. Too time consuming.
The desired effect is to have a plot file that displays the same name as the dwg file name with a different file extension. Any ideas?
