I keep getting the following error when trying to install ACAD MEP 2010.
C:\Documen~1\username\local settings\temp\_aI124.tmp\setup.exe /s C:\Documents and Settings\username\Local Settings\Temp_AI124.tmp\" /SecondRun /Language en-us
I get the same error when trying to install from cd or the downloaded trial version.
I have Revit MEP 2009, Vanilla 09, Inventor 09, Inventor, 2010 installed on the same machine.
I previously had 08 of all the above versions plus 08 ACAD MEP installed but manually uninstalled all 08 versions(no uninstall feature available from control panel "Add Remove") by removing file folders and editing the registry in accordance with the Autodesk knowledge base. I thought that maybe somehow these older versions were conflicting but no such luck.
Now I can't seem to get 09MEP or 2010 MEP to get past the above error screen.
Please HELP.
Thanks
