Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: Create selection set of newest entities created by copy command
    Active Member Borg's Avatar
    2001-04
    66
    Default Create selection set of newest entities created by copy command
    Let's say that I select a bunch of stuff and copy it. I want to make a selection set
    of the new stuff created by the copy command.
    Thanks for any and all suggestions. :
    All AUGI, all the time CAB2k's Avatar
    2016-01
    Brandon, Florida
    687
    Default Re: Create selection set of newest entities created by copy command
    You can use this
    ; Rune Wold and Michael Puckett - modified
    ; e.g. usage (setq marker (ALE_LASTENT))
    ;;  Function to get the absolute last entity in the database
    ;;  Returns nil is drawing is completely empty
    (defun ALE_LastEnt ( / EntNam OutVal)
      (and
        (setq OutVal (entlast)); if there is an entity in drawing
        (while (setq EntNam (entnext OutVal))
          (setq OutVal EntNam)
      OutVal
    ;;  Function to get new items after EntNam in the database
    (defun ALE_Ss-After (EntNam / EntNxt SelSet)
      (cond
        ( (not EntNam) (ssget "_X") ); dwg was empty
        ( (setq EntNxt (entnext EntNam)); get new items
          (setq SelSet (ssadd EntNxt))
          (while (setq EntNxt (entnext EntNxt))
            (if (entget EntNxt) (ssadd EntNxt SelSet))
          SelSet
    ;;===================  Code to get New objects ========================
    (setq elast (ALE_LastEnt)); get last entity in database
    (setq newbies (ssadd)) ; create an empty selection set
    ;; Do your array or paste command
    (setq newbies (ALE_Ss-After elast))
    ;; newbies is a selection set of all items created by your command.
    2001-04
    66
    Thanks. I'll give it a try next week.
    2004-10
    16
    how about
    (setq sel (ssget))
    (command "copy" sel "" "0,0" "0,0" "move" "P" "" pause pause)
    (setq sel2 (ssget "p"))
    126
    Quote Originally Posted by eddyhgng
    how about
    (setq sel (ssget))
    No point, really .. sel2 will contain the same selection as sel. I see only two ways, one of which is given above by Ab2draft. The other way is using the ActiveX methods Copy and CopyObjects, which will both return the copied object(s).
    13,656
    Quote Originally Posted by stig.madsen
    Hi
    Have you actually tried what "eddyhgng" posted, I think you might be surprised....
    Have a good one, Mike
    2016-01
    Brandon, Florida
    687
    I was surprised, it did work. Not sure I understand why?
    126
    Quote Originally Posted by Mike.Perry
    Hi
    Yes, line by line. It moves the original objects so that it appears to be the new objects being selected .. kinda like an optical illusion.
    13,656
    Question Re: Create selection set of newest entities created by copy command
    Hi Stig
    Can you please explain, you've lost me (not difficult I know).
    Mike
    2001-04
    66
    Reply to Eddyhgng:
    Thanks for your input.
    What I'm trying to do is create a rector(this part is done) that reacts on the copy command.
    It will then iterate through all of the new objects created by said command to check for blocks of a particular name.
    I should be able to incorporate the code AB2DRAFT to make this happens.
    Your code is valid but I don't wan't to redefine the copy command.
  1. Select the last N entities created in a lisp routine.
    By jpcadconsulting347236 in forum AutoLISP
    Last Post: 2015-06-23, 04:36 PM
  2. Create a Selection Set of Entities as They are Created
    Last Post: 2008-10-12, 06:37 PM
  3. Copy and Move command selection problem
    By smckee in forum AutoCAD General
    Last Post: 2008-09-05, 05:03 PM
  4. Replies: 1
    Last Post: 2007-03-08, 01:12 PM
  5. Slow selection of entities.
    By peter.woodcock in forum AutoCAD General
    Last Post: 2004-09-23, 01:19 PM
