Is there a way to change the physical size of the tag? Also, how does the tag change size depending on drawing scale?
Not sure what you mean here...Are you trying to change the font size?
You can change the size by selecting it and clicking Edit Family. This will open the tag in the family editor where you can change whatever you want.
The size of things in the family editor is the size that they will always plot at. If you have 1/8" high text, the text will scale, based on the view scale to always plot at a height of 1/8" (assuming that you aren't scaling the plot of course).
jason
If you click on the tag, then click Edit Family on the Options Bar, this will take you into the Family Editor where you can change the size of the tag. After making changes, Save As then Load Into Project from the Design Bar (RME 2009).
The tag size never changes. It is created based on printed size. If you decrease the project scale, the tag will appear bigger in relation to the project. If you increase the project scale, the tag will appear smaller in relation to the project.
