Results 1 to 10 of 15
Thread: Dims not working same - depends on size
    Certifiable AUGI Addict
    2015-11
    Jo'burg SA
    4,512
    Default Dims not working same - depends on size
    I'm having some problems with dimension styles. Every time a dim is so short as to have the text over both the ticks, the dimension's horizontal line extends further than normal. I've tried every setting I could think of to no avail.
    Vanilla 2008 32bit XP. See the attached screen captures.
    2006-12
    Big "D"
    3,711
    Default Re: Dims not working same - depends on size
    I think that's how it's supposed to be. Way back in the days of board drafting, I seem to remember that "small" dims like that would actually be drawn with the dim arrows on the outside of the extension lines facing in. This is the same thing, you just have the box checked to "draw dim line between extension lines".
    If you set the dimension to be set outside of the dimension lines, either with or without a leader, it will go away.
    2015-11
    Jo'burg SA
    4,512
    Still happens, even with text placed beside dim, the tick's horizontals are extended both sides (not just where the text is placed).
    While the arrow system works this way, we're using a tick instead (but for some reason a custom block). What I've found is if I change from the custom block to the standard ArchTick or Oblique, this doesn't happen. Will have to discuss this with the powers that be
    But strangely though, the ArchTick uses a block called _ARCHTICK which I can redefine to that of the custom tick and then it works. But if I simply use a custom tick it doesn't work ?????
    2005-06
    in the upper right corner
    3,524
    Quote Originally Posted by irneb View Post
    Maybe you can set your "Arrow Size" (_archtick) to something smaller in your dimstyle and it will work?
    2006-12
    Big "D"
    3,711
    Ahh, I use archtick on my dims. That's why it works for me. I wonder why your tick block would make a difference? HHHHmmmmmmmmmm
    2015-11
    Jo'burg SA
    4,512
    It seems that any user defined block would produce this "feature". What I've noticed about the custom block is that it contains both a diagonal polyline with width, as well as a horizontal line . Well I redefined it to be exactly the same as the _ARCHTICK, now it produces the attached
    2006-04
    (getpoint "Anywhere on the Enter Key =>")
    1,160
    I created a dimstyle called "123" with all settings same as what you had.
    I found no problems.
    Also, I noticed your picture of "capture_06032009_143517.png", that edit_box of "Extend beyond ticks" has been frozen.
    You are using a customized block & for some reasons it doesn't perform properly.
    I don't have any problem when using the "_ArchTick" shipped with AutoCAD.
    Please fine a sample attached.
    Perhaps you need to reuse the "_ArchTick" or recreate a customized block.
    And, the other thing is that uncheck the tick_box of "Fixed length extension lines" under the "Lines" tab will show your dim extension lines looking normal.
    Hope it helps.
    2015-11
    Jo'burg SA
    4,512
    Yes, thanks for pointing that out. However the requirement here is to have the extension lines at a fixed length so that the next row of dims are aligned with the bottom of to previous row's ext line. Previously we did this by incorporating the vertical line into the block as well & suppressing both extension lines. See attached.
    Now I can get round this using the _ARCHTICK, but then I loose the yellow tick mark. It's not a big deal, as it won't print differently. The reason behind the yellow tick mark was to see the dims easier on a black screen (while most of the dimlines are blue to "fade to background" on the black screen).
    I can redefine the _ARCHTICK to the same as my custom block ... then it works perfectly. Unfortunately the _ARCHTICK is generated from AutoCAD every time it needsa to be created in a drawing ... so I'll have to redefine it throughout
    BTW, it seems as if any user defined block is considered to be an arrow. That seems to explain what's going on. The only exceptions are the ArchTick and Oblique standard types. Rather stupid I think
    2006-04
    1,160
    Can you do it with your templates?
    - It is the drafting office regulation issue, of course.
    2015-11
    Jo'burg SA
    4,512
    Quote Originally Posted by BoKirra View Post
    Yep, templates would work for new DWG's. It's just going to be a prob to run some script to update the dimstyles in several thousands of existing current DWG's
  1. Defining duct size depends on the View or Orientation?
    By Michael.c in forum Revit MEP - General
    Last Post: 2009-08-21, 01:21 PM
  2. Bogus Sheet size (1000 times defined size)
    By bcgatti in forum AutoCAD Plotting
    Last Post: 2007-12-16, 05:42 PM
  3. Set up font size in AutoCAD to mimic Word text size
    By panchalashi in forum AutoCAD General
    Last Post: 2006-05-29, 12:22 PM
  4. Dims and Temp Dims not working sometimes
    By Chad Smith in forum Revit Architecture - General
    Last Post: 2005-12-01, 12:47 AM
  5. Size & Colour of Temp Dims and Tape Measure Text
    By Chad Smith in forum Revit Architecture - Wish List
    Last Post: 2005-10-12, 02:54 PM
