In 2010 I can't paste to orginal coordinates by the right button of mouse. Only by the menu "Edit" this command goes. Should I change some configuration? other comands in right button goes ok...
Try restoring one of the OOTB (out of the box) workspaces.
I did it, but nothing changes... always impossibile to paste to orginal coordinates by right button of mouse....
I would guess that your CUI got changed somehow. The original CUI files can be found at C:\Program Files\<Autodesk Program Name>\UserDataCache\Support.
and then? where should I put that file? I made the migration from 2009 to 2010 for all my customized files...
The default location for CUI files in Win XP is C:\Documents and Settings\<loginname>\Application Data\Autodesk\C3D 2010\enu\Support.
I've been having this same problem - and with Paste As Block as well. The strangest thing is, it works sometimes, but not all the time.
I just copied something from [drawing 1] into [drawing 2] and it didn't work, except through the Edit menu. Then, my very next action was to copy something from [drawing 3] into [drawing 2] and it worked just fine from the right click menu.
puzzling....
thanks for the Edit menu tip, much faster than the other solution I had found
What's your UCS set to? I've seen funny things happen with I try to cut & paste with a funky UCS.
When I try to paste to original coordinates within the same drawing, the option is grayed out. When I try to paste in another drawing, pasting to original coordinates works for me.
