Thread: timber skirtings and architraves
    Active Member warnoe uk's Avatar
    2004-12
    Totnes, Devon, UK
    70
    Default timber skirtings and architraves
    I'm putting together a 3d model of a converted church in the south of the uk and need to know how to add timber skirtings and architraves to my wall styles
    or is it a completly new style indpendant of the walls and doors?
    PLMK
    2002-09
    Madison, WI
    5,687
    Default Re: timber skirtings and architraves
    I'm guessing these are some type of trim piece? If so, you could add a body modifier, but since trim in a sense is a separate piece and installed later, I'd use a structural member style. Create the profile of the trim, create a SMS with that profile and place them where you want. Later, you can anchor them to the wall. SMS's will allow you to get the miter corners as such. Just a thought, That's how I think I'd do it.
    2005-07
    2,356
    For skirtings, coving, dado, etc, I'd look at using wall sweeps.
    For architrave and other mouldings around doors, windows or openings I'd add them as custom blocks to the window/door styles made out of mass elements.
    2004-12
    Totnes, Devon, UK
    70
    thanks for the reply's guys
    I'll try with the methods you mentioned and I'll let you know how I get on
  1. Timber Frame Family Help ?
    By kathey1 in forum Revit Architecture - General
    Last Post: 2012-05-18, 05:00 PM
  2. Timber with X on Section
    By Alan aka cadalot in forum Revit Structure - Families
    Last Post: 2009-10-18, 10:55 AM
  3. Timber Framing
    By paysna in forum Revit Architecture - General
    Last Post: 2008-10-03, 07:58 AM
  4. Can't get rid of architraves in arch family
    By Exar Kun in forum Revit Architecture - Families
    Last Post: 2005-06-30, 11:09 PM
  5. Timber Screen
    By PaulB in forum Revit Architecture - Families
    Last Post: 2003-10-13, 10:05 PM
