Thread: cut plane
    2007-09
    Raleigh NC
    755
    Default cut plane
    I'm trying to move the cut plane to above the doors to make a reflected ceiling plan. But changing the global cut plane for a display configuration doesn't seem to work. How can I accomplish this? Thanks.
    2002-09
    Madison, WI
    5,687
    Default Re: cut plane
    I believe you can over-ride the cut plane on an object by object basis by modifying it and applying an override.
    2011-05
    926
    ACA ships with a reflected ceiling plan display configuration. Why not use that?
  1. Replies: 4
    Last Post: 2010-04-20, 07:55 PM
  2. Sloped Bottom Plane/ Flat Top Plane
    By signalbass in forum Revit Architecture - General
    Last Post: 2010-01-06, 10:34 PM
  3. Error: Top clip Plane is set Below the Cut Plane
    By hutch_amit in forum Revit Architecture - General
    Last Post: 2008-07-14, 05:11 PM
  4. Sweep Profile plane and Orient by plane
    By dbaldacchino in forum Revit Architecture - General
    Last Post: 2006-02-03, 08:00 PM
  5. Mask difference on vertical plane vs. horizontal plane.
    By SkiSouth in forum Revit - Rendering
    Last Post: 2004-04-24, 01:08 PM
