Results 1 to 6 of 6
Thread: Service Pack Install Error
    2005-12
    6
    Default Service Pack Install Error
    Can not install any of the 3 updates for AA2009? Get the error," The service pack could not be installed because the expected Autodesk product could not be located on your computer. Make sure you are using the correct service pack for the product." I am using 64bit AA2009 on a VIsta machine and downloaded the service packs for 64 bit but get this error when trying to run any of them. One thing I am trying to fix is the SDI "0" which opens a new sessions of AutoCAD from explorer when in explorer even though the SDI is set to 0.
    I have found out at the office today that I get the same error on my 32bit XP machine here also.
    2007-12
    222
    Default Re: Service Pack Install Error
    Just ignore the error. Everyone gets the error, but the service pack should have installed. After installing it, try re-installing the service pack and it should tell you that you are up to date. You should only need to install the most recent one.
    2005-12
    6
    I really don't think everyone gets that message, but either way it's not installing. I get the same error no matter how many times I try to install the pack.
    2008-10
    I'm getting the same message.
    2007-02
    14
    I am getting this message on Windows 7 64bit and I am trying to install the service packs for Autocad 2010. Has any solution been found? The service packs are not being installed.
    2003-03
    Philadelphia, PA
    2,392
    Are you using AutoCAD Architecture 2010? If so, make certain you are installing the AutoCAD Architecture update, and not the "plain" AutoCAD update.
  1. Unable to install Service Pack 2
    By PorterCAD in forum AutoCAD Civil 3D - General
    Last Post: 2010-03-31, 03:07 PM
  2. ACA 2009 Service Pack 2 Error code 3010
    By martins.183886 in forum ACA General
    Last Post: 2010-02-05, 02:55 PM
  3. Error with Service Pack 2
    By wmeisner in forum AutoCAD Civil 3D - General
    Last Post: 2008-01-14, 07:10 PM
  4. Error 1328: Service Pack 1 will not install AutoCAD Mechanical 2007
    By svanderputten in forum AutoCAD Mechanical - General
    Last Post: 2007-01-11, 10:16 PM
  5. Unable to install latest service pack for MDT 2007
    By robert.1.hall72202 in forum MDT - General
    Last Post: 2007-01-11, 04:32 PM
