Thread: Problems with exporting from Revit 2010 to NW 2010
    Exclamation Problems with exporting from Revit 2010 to NW 2010
    I'm having problems when exporting an NWC file from Revit to NW2010. I am able to complet ethe export but when I open the NWC file in NW elements are appearing that are not visible in Revit.
    I have attached a PDF that shows the difference between the Revit and the NW file.
    In the NW file walls are protruding through the roof and windows are not appearing, as well as issues with other objects. I'm not sure if it is my settings or what. I need to export as a NWC because that holds more information in the properties which is needed for facilities management. When I export as a DWF the model looks perfect however I lose alot of data in the properties, as well it does not export any hyperlinks that were in the original Revit file.
    In addition, what is the best way to retrieve the most, if not all, the data/parameters/properties from the Revit file in NW?
    Please help, any advice will be appreciated.
    2006-05
    Portland, ME
    198
    Default Re: Problems with exporting from Revit 2010 to NW 2010
    Downloading the latest hotfix from Autodesk should take care of the doors and windows issue.
    http://usa.autodesk.com/adsk/servlet...inkID=10382102
    2008-05
    Salt Lake City, UT
    171
    I think this problem was solved through a hotfix released sometime last week.
    The export to .nwc retains most all of the properties of elements in the Revit model.
    2008-05
    Salt Lake City, UT
    171
    *look for replies before you post Mitch, look for replies...
    Thumbs up Re: Problems with exporting from Revit 2010 to NW 2010
    Thanks guys. It fixed all my issues.
  1. Revit MEP 2010 - Exporting gbXML with True North Orientation
    By smotamedi.230512 in forum Revit MEP - General
    Last Post: 2010-08-09, 10:35 PM
  2. Revit 2010 Installation problems
    By iankids in forum Revit Architecture - General
    Last Post: 2009-09-18, 07:27 AM
  3. Serious problems between Navisworks 2010 & Revit 2010
    By dramage.190144 in forum NavisWorks - General
    Last Post: 2009-09-15, 03:11 AM
  4. Problems with CAD Importing - Revit 2010
    By jhong in forum Revit Architecture - General
    Last Post: 2009-08-21, 07:13 PM
  5. Revit MEP 2010 Exporting to Navis Manage 2010
    By play_smart in forum Revit MEP - General
    Last Post: 2009-07-22, 03:21 PM
