Quote Originally Posted by cgraham View Post
If the different plans are inserted at the correct relevant elevations, the wall conflicts will go away, even in 2008. Cut planes can be set differently for each viewport, although this may require separated displays.
But all the views are inserted at the 0 elevation on the sheet set. That's where the conflicts occur. At least that's what happens in my projects. That's the work around for pre 2009, change the elevation of one of the views, even if it's by 1". In 2009 and later, you don't need to do that.
