Results 1 to 8 of 8
Thread: Add Plot Style value to layer
    2001-01
    217
    Red face Add Plot Style value to layer
    Hi All-
    I just modified a routine I have that allows me to export all of the layers in a drawing with and their values (i.e., color, linetype, lineweight, plot style name, plot and description) to an external text file. I have another routine that I modified that will read the layer text file and recreate all of the layers. After some fussing, I have been able to get most of it to work except for the Plot Style name value. I am using the following code to add the value to a layer that already exists in the drawing.
    (vl-load-com)
    (setq lyrnam "A-wall" lyrpltstyl "BLACK")
    (setq lyrobj (vla-item (vla-get-layers (vla-get-activedocument (vlax-get-acad-object))) lyrnam))
    (vla-put-plotstylename lyrobj lyrpltstyl)
    For some reason the above code will not work. Any help is greatly appreciated. Thank you.
    Manuel A. Ayala
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    8,631
    Default Re: Add Plot Style value to layer
    Have you added the Plot Style to the available Plot Styles? You can look at the "ACAD_PLOTSTYLENAME" dictionary for the list of available styles.
    2001-01
    217
    Opie-
    I did a dictionary search on "ACAD_PLOTNAMESTYLE" as follows:
    (setq psn-lst (dictsearch (namedobjdict) "ACAD_PLOTSTYLENAME")) and I found that the plot style name I was trying to assign did not exist. I have two questions: 1) how can I first test to see if the plot style name exists in the dictionary and 2) how do I go about adding it to the dictionary? Thanks.
    Manuel
    2002-01
    jUSt Here (a lot)
    8,631
    I don't know. I haven't successfully added a new plot style to a drawing through code.
    2001-01
    217
    Opie-
    Do you know how I can at least build a list of those plot styles stored in the ACAD_PLOTSTYLENAME dictionary? Also, do you know if there is a way to determine via code whether a drawing is setup for style (stb) or color dependent (ctb) plot styles? Thanks.
    Manuel
    2015-11
    Jo'burg SA
    4,512
    You can use my code in this thread to show you how to work with dictionaries.
    Typically you entget the dictionary entities, e.g:
    (setq root (entget (namedobjdict)))
    (setq ed (entget (cdr (cadr (member '(3 . "ACAD_PLOTSTYLENAME") root)))))
    Then stepping through ed each code 3 contains the name of the style, then it's followed by code 350 which contains the ename of the actual style entity.
    Or else you use dictnext. But then you first need to find the ACAD_PLOTSTYLENAME ename. (dictsearch (namedobjdict) "ACAD_PLOTSTYLENAME") gives you an entget-like list, of which the -1 code is the ename. Then you use that ename with dictnext (works similar to tblnext).
    However, the problem with dictnext is you don't get the dictionary item's name returned ... only its data. E.g.
    (setq dict (dictsearch (namedobjdict) "ACAD_PLOTSTYLENAME"))
    (dictnext (cdr (assoc -1 dict)) t)
    Returns he following
    ((-1 . <Entity name: 7efa9c50>) (0 . "ACDBPLACEHOLDER") (5 . "A") (102 .
    "{ACAD_REACTORS") (330 . <Entity name: 7efa9c58>) (102 . "}") (330 . <Entity
    Nowhere does it tell you that this is the "Normal" style. Only way of getting that is to look through the dict datalist in above code.
    2001-01
    217
    Smile Re: Add Plot Style value to layer
    irneb-
    You code and suggestions worked great. Thank you for your assistance, I greatly appreciate it.
    Manuel
    2015-11
    Jo'burg SA
    4,512
    Pleasure, glad I could help!
  1. Specify the Plot Style for certain entities in a Named plot style drawing
    Last Post: 2014-10-28, 11:52 AM
  2. Set Plot Style-Assign Style to Layer
    By jeff.richards in forum AutoCAD General
    Last Post: 2010-02-02, 05:54 PM
  3. Set a layer's plot style and description
    By brendan.j.mallon in forum Dot Net API
    Last Post: 2009-11-03, 12:32 AM
  4. Replies: 0
    Last Post: 2006-06-07, 05:15 PM
  5. Plot Style Field in Layer Dialog
    Last Post: 2006-02-21, 05:17 PM
