Navisworks Manage 2010 does not import to the correct scale!!
After exporting from xp64 Revit Architecture to Navisworks 2010 I find that when I use the measure tool it does not measure correctly!
My model in Revit is set to millimeters but the measurement I get is not even close in Navisworks. Anybody please confirm by exporting a model from xp64 Revit 2009 with the 2010 exporter plugin in millimeters and then scaling it after you import it into Navisworks 2010. Make sure you set the Global display units to millimeters. Thank you!
Dan Ramage
