dear all,
I'm currently working with MAP2005 and using raster images ( compressed lzw tiff ) to draw town maps; I can set image transparency on, and select the background colour to make the image really transparent and not to see the frame ( I mean not the image frame but a ten cm frame in each raster image); then I save the file and, when I re-open it, I can use the map with its transparency correctly working. The problem is: my collegue is working with MAP2008 (lucky man) but when he opens the same file, he can see the transparency attribute set on, but a different transparency color, so no transparency at all. Even if he sets the right colour and saves, when he re-opens the file the transparency colour is back. I think I read all the threads about it and found no way. Please can you help me?
thanx in advance
marina
