Results 1 to 9 of 9
Thread: Raster Images with AutoCAD LT
    2004-11
    Angry RE: Express Tools
    Hi, there!
    I need a menu to work with raster images in AutoCAD LT 2005, for example insert raster images, clipping options and modify image properties. When I type ... _image, the image manage doesn't allows me to browse or insert images into the drawing.
    How to add these features in a menu that can be LTXpress or whatever name would be called?
    Thanks in advance
    Hector
    CADMANAGER
    AA Architects
    13,656
    Default Re: Raster Images with AutoCAD LT
    Hi
    Have a browse of the following thread (especially take note of any links within) -
    import, insert, embed, or ????
    Have a good one, Mike
    2015-12
    Arizona
    2,478
    If you enter
    _imageattach
    do you not get a standard file selectiond dialog?
    If no check your filedia and cmddia settings to be 1(on)
    2003-09
    10
    Tried it - got "unkown command". Still baffled.
    Lee Hammack
    2001-05
    Austin, TX USA
    2,201
    Check out this TD
    Insert raster image in drawing using AutoCAD LT
    As far as I can tell, LT is very limited in its ability to handle images. Probably the only way to get some of these functions is with a 3rd party app.
    13,656
    Hi
    As far as I'm aware AutoCAD LT does not have the following commands for working with Images -
    ImageAttach, ImageClip, ImageQuality, ImageAdjust, Transparency
    If you follow the link given in my above post you will find some very useful information on working with Image files within AutoCAD LT.
    Turlock, CA
    6,374
    Slingshot adds the ability to LT to insert images. Its free. It also enables a few other things as well.
    C:> ED WORKING....
    13,656
    Hi
    The information and links I've given lead to exactly the same thing....
    2003-09
    10
    Thanks - for your time AND your patience! I'm off to order Slingshot.
    Lee
  1. Replies: 0
    Last Post: 2015-08-07, 05:23 PM
  2. GD405-2: Xrefs, Hatching and Raster Images: An AutoCAD Survival Course
    By Autodesk University in forum General Design
    Last Post: 2013-05-06, 01:42 AM
  3. AUTOCAD RASTER IMAGES
    By cadguy016681070 in forum AutoCAD General
    Last Post: 2011-09-21, 05:29 AM
  4. Attach raster images in AutoCAD LT 2006
    By SaraS in forum AutoCAD LT - General
    Last Post: 2008-11-27, 11:29 AM
  5. Raster Images
    By Exar Kun in forum Revit Architecture - General
    Last Post: 2004-10-27, 12:07 AM
