david_peterson
I believe I mentioned this in your other post.
My question, why save the .dwg? Anyone can edit it easily no matter what you do to it. If you create a pdf of the sheet, save the pdf. That's your end of the day copy. If you issued the revision and need to modify the revision you've already done, you need to revise the sheet and re-issue it anyway (ie produce a new pdf)
Until you produce record drawings, those are working documents
Also, maybe I'm just dumb today, but what the heck do you mean by "AMEP CTD"?
If you are getting runtime errors, make sure you have all the service packs for both AMEP and whatever OS you are using.
Also, are you using PN or just x-reffing them yourself? Depending on how you put your "views" together, that may be causing your problem.
But if you think back to the paper days, you made a copy (paper) and continued to modify the originals until you got to final record drawings at which point you took all the clouds off and made one final copy and that was the end.
