Thread: LiDAR Data Support
    Wish List Administration
    2007-08
    434
    Default LiDAR Data Support
    Summary: Improve the process of working with LiDAR data in AutoCAD Civil 3D.
    Description: Wish AutoCAD Civil 3D can open huge LiDAR (in .las or .xyz format) data as an object entities similar to an FDO connections without opening the files but reading the files and can create surface and contours. At present, Civil 3D crashed all the time because of the size of LiDAR data.
    Thanks.
    How Used: Most of our 3D data derived from bare-earth LiDAR data and it would be great if AutoCAD could be improved in this area (LiDAR applications - loading, surface and contours generation or even point-cloud data classification if possible)
    Feature Affinity: Surface Modeling
    Submitted By: Anthony Tam on May 13, 2009
    2005-11
    Cape May County New Jersey
    15
    Default Re: LiDAR Data Support
    I have used this technique. I imported LIDAR data into a database and processed it from there. I wish I remembered where I got this tip. We also use map workspace to connect to it as raster data if we just want to show the data.
    2011-08
    4,581
    Exclamation Re: LiDAR Data Support
    This wish has been reported as granted and already in the software.
  1. Replies: 0
    Last Post: 2014-12-17, 10:53 PM
  2. CV318-4: Connecting the Dots: Creating AutoCAD Civil 3D Surfaces with LIDAR Data
    By Autodesk University in forum Civil Infrastructure
    Last Post: 2014-12-01, 04:38 AM
  3. GS9300-1: Using AutoCAD Map 3D and LiDAR Data to Enhance 3D Maps and Designs
    By Autodesk University in forum Planning and GIS
    Last Post: 2014-12-01, 03:31 AM
  4. 2013: Lidar data- I dont want everything
    By jenniferchavez in forum AutoCAD Civil 3D - Surfaces
    Last Post: 2014-08-21, 12:28 AM
  5. Lidar file format
    Last Post: 2010-02-24, 10:59 PM
