Thread: Navisworks 2010 64bit Missing ODBC Driver support
    I could stop if I wanted to Teresa.Martin's Avatar
    2004-11
    438
    Angry Navisworks 2010 64bit Missing ODBC Driver support
    FYI. The data link tool found in Navisworks under Tools>Files Options>Data Tools does not work on 64 bit systems. You can create a new link, but when you go to select the driver you only see 4 or 5 basic ones, but not the long list you see in 32 bit. If you click on the setup button, nothing happens. Apparently, there are no drivers yet written for Excel and MS Access for 64 bit, which I guess is the problem. Frankly, I am annoyed at Microsoft for not releasing 64bit drivers for Excel and Access in MS Office 2007. I am pretty sure the only link that may work is the SQL link.
    Autodesk's development team is aware of this, but it would have been nice to know a little sooner before jumping to 64bit.....
    2000-01
    Seattle WA USA
    5,859
    Default Re: Navisworks 2010 64bit Missing ODBC Driver support
    Thanks for posting a heads-up.
    R. Robert Bell
    Design Technology Manager
    Stantec
  1. Microsoft Acess ODBC driver for 64bit XP
    By pfaudler in forum Revit - API
    Last Post: 2012-04-30, 03:56 PM
  2. AutoCAD Map 3D 2010 64bit - Oracle spatial advanced support ?
    By jprichard in forum AutoCAD Map 3D - General
    Last Post: 2011-06-23, 02:23 PM
  3. Replies: 6
    Last Post: 2009-08-04, 10:19 PM
  4. DWF Printer Driver - Vista 64 bit support
    By Dimitri Harvalias in forum Design Review - General
    Last Post: 2009-06-25, 05:55 PM
  5. Navisworks 2010 exporter from revit 64bit Architect does not work correctly
    By dramage.190144 in forum NavisWorks - General
    Last Post: 2009-06-17, 01:27 PM
