Thread: Dynamic Columns
    2015-11
    Sydney Australia
    91
    Default Dynamic Columns
    In Autocad 2010 it seems as though MText objects have dynamic columns set as the default.
    I can change this setting for each piece of text. Is there a way of setting no columns as the default?
    Just found out you set mtextcolumn to zero to fix this
    Another problem i have is if mtext is left justified and the text has spaces in front of it the insertion point is to the left of the spaces, if it is right justified and there are spaces to the right of the text the insertion point ignores the spaces
    If I use dtext it works as I want, but I would prefer to use mtext.
    Does anyone know a way around this??
    Thanks for your help
    12
    Default Re: Dynamic Columns
    Also VERY interested in a fix for this.
    Cairo - no, not Illinois
    5,069
    have you tried ending with a non-breaking space instread of a "normal" space? Insert that from the symbols menu in mtext editor...
    2011-12
    3
    2
    http://docs.autodesk.com/ACD/2010/EN...mber=d0e117430
    MTEXTCOLUMN
    set to 0
    Any already made stay dynamic, but new ones created will not be. Hope that helps
  1. Ability to "Unhide Some Columns" in a Schedule, in addition to "Unhide All Columns"
    Last Post: 2013-06-08, 05:16 AM
  2. MTEXT Automaticly going Dynamic Columns, with no width
    By Wonder Women in forum AMEP General
    Last Post: 2011-12-07, 03:24 PM
  3. scheduling columns (not structural columns)
    By ddenton in forum Revit Architecture - General
    Last Post: 2009-07-10, 07:18 PM
  4. Columns vs. Structural Columns
    By pc7 in forum Revit Architecture - General
    Last Post: 2005-04-16, 01:09 PM
  5. Structural columns - Arch columns
    By sbrown in forum Revit Architecture - Wish List
    Last Post: 2004-06-09, 12:14 AM
