Thread: Trim, trim objects/selection issue 2010
    2003-08
    70
    Default Trim, trim objects/selection issue 2010
    Hi there.
    I am using civil 3d as 2010 for some general editing of larger dwgs for use down in 14.
    I use to use 2008 and this is the first time using 2010 for this purpose in a few months.
    Although I have C3D I thought this was a more generic cad question (Hope I posted in the right spot)
    The issue...
    When I want to trim a mass of random polyline (contours) to a rectangle...I select the rectangle as the abject to trim to...then I use a crossing to select a mass of contours....my computer is taking a very, very, very long time to actually trim the objects.
    When I select the polylines one by one it is very snappy/quick.
    I have tried this with the extend and projection options in different modes and this makes no speed difference.
    With 2008 there was never a problem...very fast, very efficient in the task.
    Any ideas ???
    Thanks in advance
    Steve
    After discovering "-purge" Life is betta mon !!"
    Using version 14, because it's simple and works great, tried 'em all with time on them from 10 up moving on to 2010...someday sooner now
    0,0,0 The Origin
    8,570
    Default Re: Trim, trim objects/selection issue 2010
    Have you tried Fence selection?
    Do the polylines contain lots of short segments near the point that they cross the rectangle?
    John B
  1. Getting window trim to cut through compound wall trim or sweep?
    By Nasko in forum Revit Architecture - General
    Last Post: 2013-02-14, 04:49 PM
  2. trim 3D objects
    By BIGDIG641 in forum AutoCAD 3D (2007 and above)
    Last Post: 2008-06-11, 06:00 AM
  3. Trim :Selecting entites on the Screen without Selection.
    By balubharadwaj in forum AutoCAD Tips & Tricks
    Last Post: 2008-02-29, 05:22 PM
  4. Trim not trimming back to selected trim boundary
    By Wwhite72082 in forum AutoCAD General
    Last Post: 2007-03-23, 01:47 PM
  5. Columns and beams: to trim or not to trim?
    Last Post: 2006-02-16, 03:07 PM
