Thread: British Date format
    I could stop if I wanted to barrie.sharp's Avatar
    2009-01
    UK, South East England
    466
    Default British Date format
    I noticed when I created a drawing list that the 'Sheet Issue' column shows a date as mm/dd/yy by default. I can manually change it but it would be nice to have it dd/mm/yy as default. Any tricks? And whilst i'm on topic for formats, what's the solution for Spot Slope to show inclines as 1:15,1:20 etc?
    `Employ your time in improving yourself by other men's writings, so that you shall gain easily what others have labored hard for'
    Socrates
    2004-06
    Memphis TN area
    7,047
    Default Re: British Date format
    I'm pretty sure the Issue Date under Project Information is just a text field. It can be letters, numbers, or whatever you want.
    As for the Spot Slope, I'm not sure but I'll bet the Project Unit settings determines what that field shows, and you should be able to change it there.
    Love the Tron avatar!
    AERC, PLLC
    Hernando, Mississippi
    All AUGI, all the time gwnelson's Avatar
    2003-04
    Westchester County, NY, USA
    612
    I wanted to use a modified date format too (xx.xx.xxxx) and the suggestion here was that the format is controlled by the OS. After trying to change it in Vista, nothing happened. You might look there & have better luck.
    2006-03
    London, UK
    810
    This issue has been around for aaaages. Yes, the filed is just text so it can be whatever you want, but it is automatically filled in when you create the sheet - always in american style. There's nothing you can do. Just change it manually (you can selsect multiple sheets in the browser and do them all at once)
    2009-01
    466
    Thanks for the answers. I was hoping there might be a registry fix or ini change. As for the slope, project units don't offer a solution for british formats. I don't know why this isn't more flexible but I will have to just use standard annotation.
    Socrates
  1. Time & Date Format
    By d.stairmand in forum Revit - Platform
    Last Post: 2008-07-23, 05:54 PM
  2. Changeable Date Format
    Last Post: 2007-06-01, 01:36 PM
  3. format de la date
    By o.grand in forum Revit Architecture - Général
    Last Post: 2006-12-20, 02:17 PM
  4. How to get a date in a DD/MM/YY format?
    By eblanco_74 in forum AutoLISP
    Last Post: 2006-07-25, 06:30 AM
  5. Date format in Revit
    By phindes in forum Revit Architecture - General
    Last Post: 2005-06-14, 02:17 PM
