Results 1 to 7 of 7
Thread: Customizing AutoCAD 2000i (Pull down menus)
    3
    Question Customizing AutoCAD 2000i (Pull down menus)
    Can someone assist me in creating pull down menus within in autocad2000i. I would like to create menu's that I can insert symbols into a current drawing. I read through the autocad help for creating pull downs but it does not give me any examples as to associating the pull downs with the symbols I would like to insert. I found out how to creat the menu's at the top of the screen and how to load the. Autocad help only give me a example of a type of command. I would like to use the pull down menus for inserting symbols. Your assistance is greatly appreciated.
    Scott
    Turlock, CA
    6,412
    Default Re: Customizing AutoCAD 2000i (Pull down menus)
    Before I go there, since 2ki will be retired in Jan, do you plan to upgrade? Because 2005 has a much better solution for what you want to do...tool palettes.
    C:> ED WORKING....
    LinkedIn
    3
    Smile Re: Customizing AutoCAD 2000i (Pull down menus)
    I work for a city municipality and we are under a budget not to spend any money. I am ready to upgrading, just need the ok to spend money on it. Till that time comes I am trying to make things more efficient in our office. Like customizing autocad. I have used building systems 2005 and know what you are talking about with the tablets. If you can help I am greatly appreciated. Thanks.
    2015-12
    Arizona
    2,478
    Search the forum (here) for Tool Palettes
    and or Tool Palette Sharing there are some
    very good tips in there.
    Or if trying to create your own menus, and tool bars
    have a look inside Help file for menu customization.
    The basics are, right click near a toolbar menu, and select customize...
    Be sure to save a back-up copy of any standard menus BEFORE
    you start with any of this.
    0,0,0 The Origin
    8,570
    How are tool palettes going to help someone using A2000i?
    13,656
    Hi
    The links I give above for Tool Palettes & ABS relate to statement -
    Quote Originally Posted by sgeelmuyden
    The other links are totally relevant to AutoCAD 2000i.
    Have a good one, Mike
  1. AutoCad 2010 - Migrating MNS Pull-down menus to CUI
    By rod.238423 in forum AutoCAD CUI Menus
    Last Post: 2010-01-04, 08:33 PM
  2. AutoCAD to Remember more than 24 Pull Down Menus
    Last Post: 2008-05-28, 06:41 PM
  3. Migrating menus from AutoCAD 2000i and 2004 to 2006
    By yankee klipper in forum AutoCAD CUI Menus
    Last Post: 2006-11-30, 05:18 PM
  4. Pull-down menus - mixing AutoCAD and Desktop
    By rvorkapich in forum AutoCAD CUI Menus
    Last Post: 2006-05-26, 04:56 PM
  5. AutoCAD 2004 menus will corrupt 2000i menu file
    By dalej_k in forum AutoCAD Customization
    Last Post: 2004-06-11, 04:14 AM
