I've got an animated model, but the problem is that there are a dozen versions of this model, with each version containing different animated parts. I'd like to combine or merge these scene files into one animated model.
The first problem I'm having is that each scene has a different length, but all start at frame 0. I'll need to string these together to create one long animation.
The second problem I'm having is that each part has the same name in each model, so I can merge the models, but I don't want to overwrite an animated part. Is there an easy way to do this?
The best way I can think of that would do this is if I can copy the animation keys from one scene to another. Is there a way to do this?
Thanks for any help!
