Thread: Drop Down List
    2007-04
    17
    Default Drop Down List
    Hello all,
    I have what I hope would be an easy question to answer. I created a userform that has a 2 drop down lists in it. The first drop down list is reserved for a group name. The second drop down list is reserved for specific descriptions depending on which group is selected. For example if I select group A it shows what set of descriptions and if I select group B it shows a different set of descriptions. Each description can only be used once.
    My question is this: Can I set it up so that when I select a group and use a description out of it it will not show that description the next time I select that same group? This will make it easier for my co-workers and I to complete our tasks with out trying to remember what has or hasn't been used.
    2007-12
    68
    Default Re: Drop Down List
    well, I think theres a few things to take into account here -
    firstly, am i correct in assuming that each time a description field is selected, then there will be one FEWER description field available in the second listbox, the next time?
    if so, you'll have to take into account WHEN to make this field not available - what if the wrong description is accidentally clicked on? can he go back? or is that description gone forever? You'd have to find a separate place in your code (like a save button, or something) as to when this description is officially gone.
    secondly, am i corect in assuming that these limits, etc, will be remembered every time the program is started baxck up? if so, now you are looking at storing this data in an eternal file. How much data? What kind if data? Where is this data being seeded from? These questions will help you choose which type of external file format to store to.
    2007-04
    17
    Yes you are correct in your first assumption.
    As for your second assumption I don't need it to remember what it did the last time it was run. I will need it to pick back up from the beginning where it will have all the description available again.
    Sorry... I put in code mode now.
    Option Explicit
    Private Sub UserForm_Initialize()
        With ComboBox2
            .AddItem "Name"
            .AddItem "Birthday"
        End With
    End Sub
    Private Sub ComboBox2_Change()
        'if combo is empty, exit sub
        ComboBox1.Clear
        If ComboBox2 = vbNullString Then Exit Sub
        Const rHeaderOffset As Long = 2 'So we have a row offset on
                                        'all sheets of the workbook
        'Let's suppose that your data is in columns
        Const cDataName     As String = "A"
        Const cDataBirthday As String = "B"
        '...in the sheet:
        Const str_wsData As String = "Data"
        'Let's suppose that you populate your data on the following columns...
        Const cOutputName      As String = "A"
        Const cOutputBirthday  As String = "B"
        '...in the sheet:
        Const str_wsOutput As String = "Report"
        Dim rLastData   As Long 'used for finding last row
        Dim rLastOutput As Long 'used for finding last row in another sheet
        Dim rng         As Range
        Dim rngEntries  As Range
        Dim rngSearch   As Range
        Dim cUsedData   As String
        Dim cUsedOutput As String
        Dim wsData      As Worksheet
        Dim wsOutput    As Worksheet
        'no error handling for the case of selecting a value other
        'than "Name" or "Birthday", OK?
        'Let's determine what which column will we compare: Name or Birthday?
        'What is the last row of the Names column?
        Select Case ComboBox2
            Case "Name"
                cUsedData = cDataName
                cUsedOutput = cOutputName
            Case "Birthday"
                cUsedData = cDataBirthday
                cUsedOutput = cOutputBirthday
        End Select
        Set wsData = Sheets(str_wsData)
        Set wsOutput = Sheets(str_wsOutput)
        'Before we add data on our combobox, we need to test if it is already used.
        'So, we need to test EACH entry that should enter.
        'Let's determine which is the last row so we can loop through the column:
        rLastData = wsData.Cells(wsData.Rows.Count, cUsedData).End(xlUp).Row
        'What's the last line where it exists entries?
        rLastOutput = wsOutput.Cells(wsOutput.Rows.Count, cUsedData).End(xlUp).Row
        'Before adding entries to combobox, we need to check if it doesn't exists in THIS range:
        Set rngEntries = wsOutput.Range(wsOutput.Cells(rHeaderOffset, cUsedData), wsOutput.Cells(rLastData, cUsedData))
        For Each rng In wsData.Range(wsData.Cells(rHeaderOffset, cUsedData), wsData.Cells(rLastData, cUsedData))
            Set rngSearch = rngEntries.Find(rng)
            If Not rngSearch Is Nothing Then
            'OK, this means that found a match... so this entry will not be added
            Else
                '...else, we will add the item!
                ComboBox1.AddItem rng
            End If
        Next rng
        'Let's release all the memory we used on these objects:
        Set rngEntries = Nothing
        Set rngSearch = Nothing
        Set wsData = Nothing
        Set wsOutput = Nothing
    End Sub
  1. drop down list
    By cparvez in forum Parts Builder
    Last Post: 2012-08-05, 01:18 AM
  2. Drop Down list
    By cparvez in forum Revit MEP - Families
    Last Post: 2012-07-30, 08:09 PM
  3. CTB unselectable from drop-down list
    By matt.worland in forum AutoCAD General
    Last Post: 2006-06-23, 11:40 PM
  4. Drop down list for fields
    Last Post: 2006-02-21, 05:19 PM
  5. Drop down layer list takes FOREVER to drop!
    By b_v_mc in forum AutoCAD General
    Last Post: 2005-12-05, 02:50 AM
