Thread: Renumbering Table Tags
    2015-05
    West Des Moines
    306
    Default Renumbering Table Tags
    Anyone have a quick way to renumber tags? I don't see any CAD functionality for it. Maybe a lisp routine or something?
    I have an 87 curve table that I need to add two curves into. Since it's for my first page I don't want it to have curves 1-6, and then 88 and 89. The only way I know how to renumber tags is to renumber all the tags to a "bad" number, insert the new curve tags to the correct number, then manually renumber everything again. I'd prefer to avoid that if I can. I am usually pretty attentive in my tag numbering since I deal with so many on a regular basis, but every now and then I slip up and miss a curve or line and then I'm stuck with the consequences.
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,106
    Default Re: Renumbering Table Tags
    Unless I am missing something, you won't be able to use AutoLISP to handle this task. However, I haven't studied this long enough to completely rule it out.
    Add this to an expanding list of things Civil 3D hides from AutoLISP.
    2014-08
    448
    Hi
    there is a command to renumber the tag in the context sensitive ribbon. But first you might what to pull the line curve label dialog box at the bottom is a dialog box to set new tag label number
    2015-05
    West Des Moines
    306
    Well that's a bummer.
    Quote Originally Posted by remi678731 View Post
    Hi
    I'm aware of this functionality, it's what I currently do. To reiterate...it's just clunky. If you have 100 tags, you realize you missed one, and it should have been tag 4 you now have to renumber 5-100 first, then go back and add the tag in as 4, then renumber the tags again to get everything to look right. The earlier you made a mistake in the numbering, the more annoying it is to fix it. Hell, it'd be nice if we could do reverse numbering, then I could just set it to 101 and go backwards. And don't even get me started on ghost tags...
    Ultimately part of the reason I made this thread was just to see if anyone challenged me on my workflow. So far no dice.
    2002-01
    jUSt Here (a lot)
    9,106
    Can't challenge you on your workflow when it is the only one readily available.
    Great. That sounds like a meme.
    2015-05
    West Des Moines
    306
    >Lays down
    >Tries not to cry
    >Cries a lot
  1. Renumbering Tags - question
    By crullier in forum NavisWorks - General
    Last Post: 2012-09-07, 09:03 AM
  2. Table tags in an xref drawing
    By brainman1000 in forum AutoCAD Civil 3D - General
    Last Post: 2009-08-25, 05:21 PM
  3. Renumbering Door Tags
    By katysue in forum Revit - Platform
    Last Post: 2008-09-22, 09:02 PM
  4. Renumbering Rooms and Door Tags
    By Michelle Gibson in forum Revit Architecture - Tips & Tricks
    Last Post: 2008-06-04, 06:44 PM
