Thread: Dynamic Block - Viewport Scale
    2016-01
    5
    Default Dynamic Block - Viewport Scale
    Hi,
    Is there a way to report using fields (or similar) the scale of a viewport in a block this would save me a huge amount of time changing text to the scale of a the viewport.
    I have found something within Sheet Set Manager but I don't use SSM thus it doesn't work.
    Suggestions would be very grateful
    Stenna
    2001-05
    Austin, TX USA
    2,201
    Default Re: Dynamic Block - Viewport Scale
    In the Field dialog, look in the Objects field category and select Object in the Field names pane. You can then select the viewport and one of the properties is displaying the scale.
    Glenn Pope
    Civil Designer/CAD Manager
    River City Engineering
    AutoCAD Civil 3D 2011 Ver. 3
    Windows 7 Pro 64bit
    I explode MTEXT.
    2016-01
    5
    That is spot on thank you very much that'll save me a whole load of time
  1. Field for Dynamic Viewport Scale
    By BThiele in forum AutoCAD Fields
    Last Post: 2014-02-04, 02:14 PM
  2. Annotate Graphic Scale Block by Viewport scale
    By msmith.109036 in forum AutoCAD Customization
    Last Post: 2013-11-12, 05:58 PM
  3. Replies: 0
    Last Post: 2013-11-08, 05:29 PM
  4. Object / Viewport Scale field in a block?
    By Cavediver in forum AutoCAD Fields
    Last Post: 2012-09-04, 03:22 PM
  5. dynamic block to scale by viewport when loaded
    By tim.ashton in forum Dynamic Blocks - Technical
    Last Post: 2006-06-14, 09:45 PM
