Results 1 to 1 of 1
Thread: Pipe Rise/Drop Display Problem
    2008-06
    VA
    165
    Default Pipe Rise/Drop Display Problem
    Hi all,
    For some reason, AMEP09 is not displaying the rise/drop symbols for elbows correctly. I have attached a screenshot to help clarify my situation. On the left, you can see the problem: on of the elbows displays correctly, but the others (the ones down/left of the correct elbow) just show as white dots. Just for clarification, a 3D iso view of the pipe connections/elbows is shown in the right viewport (view from SW iso) in the screenshot. In other locations with the same configuration, ALL the elbows show up just as white dots.
    Has anyone else run into this? Could it perhaps be because the pipes are too close together? (Although this exact same configuration shows up correctly in other locations (see 2nd screenshot)). Any ideas on how to fix this? (I've tried REGEN, OBJRELUPDATE, and restarting AMEP; no luck.)
    Thanks!
    -Brad
    Revit MEP 2013 - x64
    AMEP 2012 - x64
    Windows 7 - x64
  1. 2013: Pipe rise/drop symbols on RCPs
    By matt__w in forum Revit MEP - General
    Last Post: 2013-04-22, 02:26 PM
  2. 2012: How to control Pipe rise/drop annotation size to mininum value?
    By sensei_jay2008 in forum Revit MEP - General
    Last Post: 2012-11-30, 09:52 AM
  3. Pipe Rise/Drop Symbols & Linetypes
    By Illiniwek in forum Revit MEP - General
    Last Post: 2012-08-23, 01:58 PM
  4. No line type override for Pipe Rise and Drop symbols and Pipe Accessories
    By Wish List System in forum Revit MEP - Wish List
    Last Post: 2012-07-24, 05:45 PM
  5. Pipe-Rise/Drop annotation issue
    By luigi in forum Revit MEP - General
    Last Post: 2011-05-25, 11:38 PM
